Just make sure the grease is compatible with what is in your machine (check a compatibility chart). An incompatible grease will result in it rapidly degrading and running out usually wrecking the bearing.
Also, I would use a hand grease gun, that allows you to feel when you start to pressure up which prevents blown seals which also leads to wrecked bearings.
