How to adjust the holding brake system on an Argo. The right holding brake is keeping the stick from going up against the dash block?
Stubborn holding brake
Also I noticed I am using the springs that are used in the chain tensioners, maybe that could be the problem? But it seems like the steering colum is to far the the left because the metal frame under the steering levers actually goes into the spring and is caught in there. Will try new springs and then will adjust? Any ideas if I am still wrong
Adjust the body support that rests on the trans, lift the body upward while tightening it.sigpic
So going blindly into this query, is it possible that you have either trapped the throttle cable under the spring or assembled the twist throttle in a way that it contacts the dash board obstructing the free travel of said stick?sigpic
Ok let's get this strait lol sorry for all the confusion,my Argo is in at the cabin 10 min from here,there was no school for me the past two days due to storms,so I change a picture of I sorry. Ok here I is with the two springs on the left stick hits the dash block normally and the right one stops but almost there.the little tab sticking out off the right stick that the holding brake brings up into hat tab brings up in the arm of he holding brake. But say if I wanted to use the holding brake the right one works good but apply the left one the the holding brake skips of that tab on the steering lever and he steering lever goes against the dash block.
So just looking at the picture in your gallery (kinda small and grainy or foggy) it looks like the holding brake arms need to be spread apart as they look slightly bent inward, the 2 allen head bolts in the holding arms should be near center of the roll pins crosswise in the sticks. Hope that works.
Next, I can't see it well but, kinda looks like the throttle cable is wedged between the dash and the firewall instead of in the opening it sits it for free travel.
Good luck.sigpic
