Mount
Tube is 1.25 square tubing. (do not know the wall thickness)
Bracket is set 13 inches from light.
Square tube length is 15.25 with diamond offset.
tube attachment flat stock is 5.25 and 90 to frame is 3.0 inches with to 5/16 bolts at hitch to frame. 3/16 steel for this part.
Motor mount plate is 9.25 inches long with 2.50 deep to 3 point weld.
Motor mount back plate is 4.50 inches (all plating is 1/8 steel)
Plywood mounting plate is 1 and 3/16 inch.
Angles are noted: first pic is to set back plate at 75 degrees with angle meter as pictured. This is a ruff estimate since i am not completely level due to the vehicle design. Rear wheels about 1 inch off ground in rear.
Square tubing is set at 70 degrees on angle meter and welded in diamond position. I am sure you know what i mean by this.
Hope this helps . I mound a 9.9 4 stroke on this and is pretty sturdy set-up. I am positive a trolling motor will be o.k. on this application. Good luck:
Lewis
Lewis
Just thought i would add this, i normally keep it very clean.
