I think I found my problem.R/H brake caliper dragging more so when warmer.I adjusted steering pins per manual no change.Flushed and bled brakes no change.Removed and disassembled R/H caliper found two o-rings were there should only be one.The second o-ring looks like it is slightly blocking the hole.Probably more so when both caliper halves are together and torqued.I am the second owner and purchased the Argo about a month ago.Photo attached.
01 Argo Brake drag
Originally posted by 01argo View PostI think I found my problem.R/H brake caliper dragging more so when warmer.I adjusted steering pins per manual no change.Flushed and bled brakes no change.Removed and disassembled R/H caliper found two o-rings were there should only be one.The second o-ring looks like it is slightly blocking the hole.Probably more so when both caliper halves are together and torqued.I am the second owner and purchased the Argo about a month ago.Photo attached.
Originally posted by philipatmaxfour View PostCongratulations. Many many people would not have found that!
Originally posted by Canadian_Zuk View PostI hope that's all it turns out to be. I'm curious and can't wait for you to get it back together, I'll honestly be surprised if that turns out to be source of your problem.
Do you believe it was the small oring or did you do the ones on the pistons as well?sigpic
Originally posted by ARGOJIM View PostDo you believe it was the small oring or did you do the ones on the pistons as well?
