All,
First off, I am new to the Argo world. I just purchased a 2012 8x8 Argo Hdi with the 750 efi engine. The machine has rubber tracks on it also. I read these machines will do about 20 mph, so I am assuming that is without the tracks. How fast should it go with tracks on normal level ground?
I can only go about 6-8 mph with the tracks on. Is this normal or not? Don't know if I need to look at something, like clutching.
I am sure I will have many more questions, as I am just learning about this machine.
Thanks for the help!!
AkBillyBow
AkBillyBow
hello akbillybow- we can assume that since you said "rubber tracks" that your machine is equipped with Argo rubber tracks. If that is true,the owners manual has great detail on how to set up both the tire diameters and tire pressures. It is surprising how much difference there can be in measured circumference between two otherwise identical tires with the same pressure. For that reason it is necessary to measure and mount your tires in prescribed positions. If previous owners have not done this you can face the dreaded "chain windup"  caused by some tires applying a braking action to larger diameter that that want to travel a greater distance on each rotation but are chained together to the smaller diameter wheels. If that is the case with your machine it will cause additional stress and breakage on your drive train.  Rubber tracks have  great traction between the track and the tires and are therefore most susceptible to this type of damage. Welcome to this forum and congratulations on getting a great machine.
