i assume your talking about those little clips on the end that hold the end plate on,just take a tooth and one of those clips from the new box of chain and play with for a bit to get familial with how they work. i like to use a little fine point flat SD and pry one end off the tooth and just pull down or up to remove it off the other tooth. like i said just play with it for a bit and you will be able to picture how i do it or a different way that you will come up with. start in the rear also they are easier to put on and work your way to the bow. thats where it gets crafty. also notice how there are two plates in the middle and one plate on the end, for the front or hard ones to put on i just use one plate in the middle and one on the end followed by the spring clip.
anyone against what i said about usuing only one inside plate tell me! is it still strong just with one plate?
that's funny
