I am looking at a 1989 Argo Magnum locally. Has a new engine and a new drive clutch and appears to be in decent shape. This is probably a stretch ( I'm a dealership service manager so I recognize how this question sounds ) the owner says the Magnum only turns left. Is this symptom something that screams "this specifically causes that" or as I suspect is it a condition that could have many causes?
Question for you Argo guys
Could be something as simple as no brake fluid in the right side or like Curtis said break pads but... Could also be a bad master cylinder, blown brake line on the right, seized caliper, etc."I've yet to encounter a problem that cannot be solved with the right mixture of whiskey and weaponry"
:ME....
" From my cold dead hands"
:Charlton Heston...
"Only turns left" as in "will not turn right but still goes straight" is most likely a brake issue, worst case scenario is still a relatively cheap fix.
"only turns left" as in "only turns left, even when I want it to go straight" could be a whole bunch of other issues, like an unahppy transmission.
