I don't know what type it is. But the argo always starts very well when it is cold. It is when it warms up that I have problem. I think that there is a crack in the valve cover, could that be the problem
carb problem or what
if you have a pulse type fuel pump, and the pulse line comes from the valve cover with the crack, it certainly could be the problemA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
Fuel pump is arm driven, check the fuel line hell check the back vent for mud/bees/ spider. If you run the engine til it dies and remove the cap (hearing suction) and it's good again, I'd say vent system.
Brian Kohler Aegis LH685, probably has the accelerator pump on the carb..sigpic
Today it was worst. It ran for about 10 minutes than stopped or nearly stopped. I made it back on reverse with the choke on. It seems that the only way to make it run is with the choke on. I play with choke and throttle I could see fuel going throu it and sometimes it empties and fuel come back in the filter coming from the tank. Sometimes fuel comes throu and sometimes it stops. Does the fuel go in the filter continuoustly?Jack
Hi guys, it got worst. I hardly made it to the camp. Had to walk back. I cut a piece of the air line from tke fuel tank to the rear of the argo. It was blocked. Maybe I should take all out. I ran with the gas cap off. No difference. It goes for a few second than stop or no power to go furthur. I wait a few seconds and it starts like a new one but doesn't stay. Finelly made it to the camp. I cleaned the hose from the pump to the carb. It had a bit of dirt in it. start it with the hose off to see if it was pumping fuel and yes. I took the carb cap off and cleaned the gasket that sticked on it. Put everything back in and it is worst. It starts right away then no power. I need to put it on choke to make it run. I had it choke on with a bit of throttle and it runs but as soon as I give more throttle it stops. I don't know what else I should tryJack
I didn't read your thread in detail. However I would try the following.....
1. Remove filter and blow back down the fuel line, check if there is a restriction, I have seen the pick up pipe blocking, and the fuel hose getting nipped inside the body. The pick up pipe runs dry, leave it a minute and it will fill back up, the machine starts, runs then cuts out after a short time.
2. Check the fuel solenoid is working ( it operates with the ignition switch, pull your fan switch and you can hear it click)
3. Make sure your carb float/needle assy is working correctly
4. Check the carb solenoid fuse is located correctly and corrosion free, I have had an intermittent fault with this before
5.
Hi and thanks for your help. I think I know the problem but don't know where to look or what to fix. I partially blocked the hole on the air filter. It ran better, on the way I had to run with with choke close. It seems it is an air problem. Sucking to much air. I cut a piece of the air hose from the gas tank. It was blocked. But that didn't fix the problem. Maybe it is blocked further. I tried running with the gas cap off or opened a bit. No difference. So the problem is too much air. The carb can't be ajusted on that motor. So it is sucking air somewhere but where. I needed to run slow. When I give more throttle it wanted to stop so problem when I tried to turn since I have to give more throttle. I just don't know what else I should tryJack
So hard to diagnose this on here, try spraying the carb linkage on the side where it leads down to the accelerator pump with wd40, while doing this and rotating the throttle a little extra sprayed around carb at idle will tell if you have an air leak.sigpic
Put a boat primer bulb in-line so that you can ensure you have purged the line of air and make sure the bowl is getting enough gas. After that trouble shooting is easier. This can act as s back up fuel pump as well, just put it in a spot that you can easily reach while driving.
Thank you for the hint. I'll try that the next time I'll go to the camp, next wednesday or friday. Moose hunting begins saturday. I hope I won't have to cary again on my back. It is only 1 mile but with some weigh on the shoulder and walking in some mud. it gets tough for a 60 year old man.Jack
Too much air is another way of saying not enough fuel.
So:
1. will only run choked.
2. un-choked it will run sitting idling with no load.
3. If you give it throttle un-choked it will die.
4. It will sort of run semi-choked with a tiny bit of throttle but if you give it more throttle, it will die.
5. Sometimes when it dies it has to sit before it will run again.
Probabilities:
Fuel delivery.
Float adjusted way too low.
Plugged port in the carburetor in the low idle circuit or at the change over to high idle circuit.
Test the fuel delivery by taking it out of the equation. The engine should run with gravity fed fuel so make yourself a small tank out of a pop bottle or something to feed the engine and take the delivery hose from the pump to a bottle to measure the flow from the pump. Visible air in the filter is usually not a problem.
Float adjustment and plugged port can both be looked at with a cleaning look see. The plugged port can be a bear to find sometimes.
The won't start for a bit is kind of an outlier symptom; especially since you don't have electric fuel pump. Vacuum locked fuel tank or super slow fuel delivery from an electric fuel pump would be my guesses for that. I'm wondering if this might be just a bit of flooding due to trying to run it choked.
Anyway, those are just my guesses.
But I do hope you get it running. I'm not 60 yet (but not all that far off) and having packed elk out of wilderness areas I relate to that last comment of yours.
[Edit]
Okay, page 20 from this manual - I haven't found where it says what the pumped flow rate should be (but I admit to not reading it fully). It does mention a fuel shutoff solenoid. I can't remember if anyone has already mentioned it but it too can cause this.
I would still try and split delivery from carb issue.Last edited by JohnF; 10-03-2016, 11:50 AM.
Simple trick to clear a plugged jet... sometimes it works, sometimes it doesn't. remove the entire air cleaner assembly. get the engine reved up as much as you can, then cover the carb as opening as tightly as you can with the palm of your hand. this will creat a high level of vacuum in the carb, and CAN pull the debris through the port that it is clogging. Engine will flood and sputter try to get your hand off before it completly dies so you don't have to restart it multiple times. takes a bit of practice. I usually do this 4-5 times... if it isn't better by then,this method won't fix it.
also, verify that it is running on both cylinders. is the exhaust hot just beside the head on both cylinders after running for a short time? Most v-twins will run ok at no load on 1 cylinder, but be awful under loadA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
