What is the best way to jack up your Argo to grease the bearings? I have been using a floor jack and 1" piece of black pipe to distribute the weight.
maintenance
I have a Response 8x8 i drive up on a three two by six's with the front tire resting on the boards and work on the second axles. then drive the second axle onto the board and can do the remaining three without having to move the machine again. If you get two of the four back tires off the machine will want to lean forward. Anyway works for me.
Hi guys. I use my motorcycle jack. You know the ones they advertise as a motorcycle/ATV jack? It has the right width for my 6X6 and I get the front an middle axle off the ground, then when they are done I jack up the back. I live in Canada and purchased it at Princess Auto, but I have seen them in the States at Costco, Harbour Freight and such. Pretty good prices too.
Cheers
Craftsman ATV jack.
Craftsman Motorcycle/ATV Jack - Model 34612 at Sears.com
It will lift my 6wheels off the ground! Makes life great when I can sit on my creeper seat, and just roll around the argo.Jeff
02 Argo Bigfoot
Sears jack
Greasemonkey, is this ATV jack stable enough after you get the Argo off the ground, to crank the Argo up and put it in gear to run the chains to oil them??? Guess it must fit in between the tires right?? Thanks for the suggestion.
Dennis"Let's Roll" when he used to wake me up in the mornings for school in the 50's.
My Dad, Utah Beach D-day vet, 79th Inf Div
Originally posted by bearclaw46 View PostGreasemonkey, is this ATV jack stable enough after you get the Argo off the ground, to crank the Argo up and put it in gear to run the chains to oil them??? Guess it must fit in between the tires right?? Thanks for the suggestion.
DennisDerek
THANKS!!!!
Derek, Greasemonkey,
Thanks, guess I know where my next semi-weekly stipend from the financial mgr is going next week. I'll have to see if my Sears store has one. I actually have a Craftsman electric impact wrench I bought in the early 80's and it does a heck of a fast job pulling those tires and putting them back on for greasing the bearings.
Milwaukee 9082-20 14.4V 3/8" Impact Wrench - Tool Only - ToolKing.com
Good investment also, along with a set of decent inpact sockets.Jeff
02 Argo Bigfoot
