got 2 new leds for the front of the Argo. 1st question is how can i prevent the wires on the exhaust side from melting and 2 how do i wire it.also do i need a relay for the lights that makes 3 questions but oh well!!
lights install
While you can buy "high temperature" insulated wire to do the job, re-routing your regular vehicle wire a few more extra inches, away from the heat source, would be a much simpler and less costly option. Having worked over 24 years for a leading manufacturer of high temperature wire and cable, I can state that with some authority.
If you need a relay and don't use it, the contacts in your switch won't last.. They'll get burnt out from the internal arcing when you open and close the switch.. If the rating on your switch is higher than the draw on the LED's, then no relay is needed...Originally posted by curtisbyrne View Postwow,never heard of him sounds like a person who forgot he already had a thread about this lol. thanks glen but that about wiring them do i absolutely need a relay if not what will happen?
I sell MAXXIMA LED light at work and I will tell you thy draw MILLY AMP's compared to a Regular light so I would say you don't need a relay at all. Just when you hook them up thy will NOT lite if you do it backwards ! You won't hurt them but there Ground is there ground so test them first .
Did your lights come with any instructions or information sheet? See what the instructions tell you about a relay and if they tell you nothing, check the info sheet to see if it tells you the amperage the lights draw. Compare that amperage to the amperage rating of your switch. If the only detail you have from the manufacturer is watts, then you can calculate amps using this table.
Watts to amps (A) conversion calculator
You have a 12 volt DC system.
I calculated 26 watts as pulling slightly over 2 amps. Your typical rocker switch is rated for well over that (10 to 20 amps perhaps).
FD SALES -- AN AUSTRALIAN BASED COMPANY — 27W LED Flood Work Lamp Round Off Road Light
there like this but 6 lights instead of 9
Here's 2 cents from a newbi in 6x6 but old timer in work boats and fishing gear for my fishing boat I use led lights from superbrightleds.com they have a assortment of high output led lights that are low wattage we use the rgb lights for the general lighting on the deck for working at night. The reason is so we don't need 4 batteries to run the electronics and lights Hope this is some help.
OK. after searching on google i found the exact one. it says 18W.
the switch is 2 prong similar to the one at the bottom. i will read the amps on the switch to be sure but this one says 20 amps.would that be good?also should i add an inline fuse. im not tying into the original lights as well.
