how would i tie into the stock lights?
lights install
If you tie into the same wire and leave them hooked up yes. But thy will come on with them all the time.
Or you could just hook them up to the high beam side. You will need to look over your wiring real good to figure it out as I am not there to see what is what ?
Do you have or can you get a wirering diagram ? That would help you out greatly !!
Ok so your switch is rated at 15 amps. Now Your lights will have a amp rating also. So add the two light amp ratings together and if it is below 15 amps your good to go !
I am sure it will be ok as I sell just regular toggles all the time with the LEDs I sell at work.
