anyone know what lube to use on the clutches of an older argo? (80's) also where do you need to lube them? i looked at how they were moving when i reved the engine in neutral, then hosed them with silicon spray and checked it again. they seem to be moving a lot better... i just need to know if i should brake clean them out and use some other type of lube
thanks
thanks
