So I purchased the hitch mount for $29. I read online and saw that it is only rated for 100lb of tongue weight and 1800lb of pulling. I used 5/16 bolt and as I was tightening them down I heard a giant crack. The bolt broke, but more importantly the frame inside actually caved in. Must have been weak or partly rusted. So I welded it up then put a 1/4 steel backer plate to help add strength.
Unfortunately, whoever had the unit before me snapped a bolt in one of the holes and I could not get it out. I tried using an extractor and drill it to no avail, so I am stuck with only three bolts holding it on.
I ordered grade 8 bolts and nuts so I can really tighten the three down and make sure it is nice and secure.
I then cut and re-welded a platform for extra storage, guns, coolers, etc. I also plan on adding plywood to make some custom mud flaps so everything doesn't get covered in mud.
I think it came out good!
