I need to remove a brake disc. pulled the center bolt but it wont budge. Manual says if its stuck to use a "wheel puller"  I have a gear puller which I think is the same. Grabbing it by the center teeth would likely break a tooth. Only other option is to grab is around the perimeter of the disc but I'm concerned about the pressure warping it.
Any ideas? Kinda in a jam here.
