1972 Argo 6x6 with Kohler K3992ST 2 cycle engine
  • 1972 Argo 6x6 with Kohler K3992ST 2 cycle engine
    This is my first time starting a discussion on this website. I have what I was told by the Argo company based on the serial number is a 1972 Argo 6x6. It has a Kohler K3992ST 2cycle engine. This was given to me by my best friends family. It has has not run in probably a little over 20 years. The engine did run the last time it was used. A chain link had broke on the main drive chain and they just never fixed it. It then it sat in their barn for years where several tires, and the belt dry rotted. It was never really maintained because it was at there place up north so it was a kind of go up for the weekend play with the toys but no time to maintain kind of thing.
    I have had it for 2 or 3 years now but just recently started working on it. I did recently start a discussion on a vintage sled website about the Walbro WR-1 carburetor that is on it and talked a little about the clutches. I have spent a lot of time just trying to get everything cleaned up as good as I can. It already looks completely different then when I initially got it.
    Currently I have the engine and tras removed. I had an incredibly hard time removing the driven clutch until I finally bought the correct tool from Richard's Relics. It was already not in great shape and was further damaged by my attempts to remove it before buying the tool. I was in the process of making a tool to remove my primary when my buddy stopped by and said let's just try the water trick. He said "it can't hurt to try". Unfortunately it worked but popped of so violently that it shot up into the air fell to the ground and broke. That clutch was in good condition. Still trying to get over that one. I bought a new Comet primary that looks completely different than the original, a NOS Salsbury Comet driven clutch that looks almost the same as the original, and a new belt that seems to match size wise accept that the one that was on it previously seemed thicker. These were also purchased from Richard's Relics. I was told these would work for me. Sure hope so because I am not yet at a point where they could actually be tried yet.
    As far as the engine goes the only place I have seen this exact model number listed anywhere on the internet has been on this website. I have been just trying to clean the exterior of the engine up without disassembling anymore than I have to. I have removed all of the engine cover pieces, the large front aluminum face, the pull start housing, the exhaust, and the intake and carb. I am trying to clean it up as good as I can without disassembling any further than this.
    All of the parts, manuals, etc. that I have found on the internet are listed for K399-2, K399-2T, K399-2T FC/2. I cannot find anything listed for K399-2ST. Looking at the manuals that I have found for K399-2 and K399-2T everything for the most part seems to look visually the same accept for maybe the intake. I bought what is suppose to be a complete gasket kit off amazon Winderosa K399-2T FC/2. The exhaust gaskets seem like they may work but not quite an exact fit. The intake gaskets seem like they are not going to work. There is a spacer that goes between the engine and the intake that had a gasket on each side of it. The gaskets that come with it do not look like they would work with these spacers. I think the other gaskets may possibly work for the rest of the engine but I am not sure so I don't know if I should try and return this set or not.
    If anyone else has this engine or has had it and could please tell me anything that you have found out about compatibility of parts with these other engine models I have listed. Especially gaskets or what you may have done if you ran into these type problems yourself I would really appreciate it. I have seen people say in other discussions to just swap this engine for a 4 cycle but that it not something I am interested in doing at this time.
    I also am trying to figure out what type of chain, and bearings I should purchase. I have determined that the majority of the chains are single #50, and the 2 in the fro t are single #40. However when I look online it appears that there are several types of each of these and a bunch of different brands. Standard, heavy, o-ring, and some other stuff as well. I have seen from about $20 for 10ft. Of #50 to well over $100 for 10 ft. Of #50. So I would also really appreciate advice on this. Please be as specific as you can. I have seen people recommending brands but most were much older posts and they didn't necessarily tell you the specific type to get of that brand.
    As far as bearings I don't think whatever is in it now would be able to be greased or anything like that. Not sure if it would be possible to upgrade them in a way that you could without completely replacing axles and stuff like that. I do think that one of the axles may have been replaced at some time because it looks thicker than all of the others and the gear that is on it slides back and forth where all of the other gears in it are welded on. If anyone can tell me more about the bearings from this year of argo that would also be very much appreciated.
    I really appreciate any help anyone can give. Also I have taken pics of everything so if anyone would like to see something specific please let me know and I will try to add 20191209_013253.jpg20191213_210831.jpg20191226_200935.jpg20191226_232525.jpg20191230_161106.jpg
    I just kinda added a random assortment of pics but like I said I have pics of pretty much everything so let me know if you want to see something specific.
      Looks good. And my favorite price too lol. the only advice I can give is don't rush, or cut corners. It's already pretty nice and will be so much nicer when you're finished.
      DanW
        Wow! That is a clean hard body machine!
        I have one with a rough body that day outside for 15 years and has been sitting outside 10 more since I got it, the frame was and is junk but recently sourced one for it.
        The original axles are 7/8" and the upgraded/ later one should be 1" , none of that has been available Osince the 70's. I have not looked at mine for a while but the bearings should be 52mm so the greasable flanges may be available, should you get to the point of doing them I would bring the bearing and flangettes to the bearing house. Should you need axles a machine shop may be inline. The rest looks really clean including the factory Argo windshield.
        At some point I may not you up for all of your pictures as that may be the best example of a hard body I have seen since the 80s, please do not paint it.
        Good luck with it.
          Thank you it has taken a lot of effort to clean up what I have so far.
            I haven't worked on one that old, but as for the gaskets I would make your own out of gasket material. It’s easier and cheaper then buying the wrong ones three times like I did. If you have the original gaskets still intact use them as a template, if not try find a pic of the correct ones. Lots of times they are pictured on graph paper the has 1 inch squares. Then I print out the pic and then measure the squares. I reduce or increase the size of the image until I get one inch on the squares and bang you have a template.
              I could probably use the spacers to trace the intake gaskets. In the gasket kit that I bought, the gaskets for the exhaust had metal sandwiched between 2 pieces of gasket material. Can you purchase gasket material like this? If you can what would be the best way to cut through it without damaging it? If not can you use gasket material that does not have metat in between it for an exhaust? The originals that I pulled off did not survive. They did not have metal in between, but it also appears that they were leaking, and I think that they may not have been the originals.
                wow piece of history right there! looks like shes in good hands
                  Trying my best
