2010 HDI , Snapped two mid axles. Uncertain as to why. Ideas ???
Snapped 2 Axles within 25 hours. Tire pressures OK.
where did they break? Tracks, track tuners, and/or total time on tracks? Machine speed, cargo on board, and terrain conditions when it happened? It’s usually the welded area of the older stamped flanges as mentioned already, after a shock load, but I have seen axles break clean right at the outer bearing believe it or not. That particular machine had about 200+ hrs on factory rubber tracks? My guess is sudden shock load (speed over bumps) or heavy throttle against a sudden, heavy load. Just (ideas) though😊
Well, it was the same side, one rear & the other mid next to it. They did not break at the same time. No cargo to speak of. Not fast, & fairly easy conditions at the time of breaks. Not saying they may have had some stress before hand. In any case i have a spare aboard now. Both times i managed to remove wheel, & go along on 3 on one side. Yes with tracks. Uncertain of the issue, but am thankful for the replies !!! i try to keep up on the argo. Now getting ready for the moose hunt here in NL where i guide. Thanks ??? Respect !!!
