ever since i bought my 2012 hdi ive had and issue where 50% of the time when i try to start it i get only a click and no crank.release the key and try again and away it goes as it should.initially i thought the battery may have been weak so i chucked a good agm battery in but the same thing happened.took the starter out and replaced it with my brand new spare but got the same result.changed the spade connector that goes to the starter solenoid but there ws no change.i wired in a separate relay that took power right from the main power from battery then to the the starter solenoid.but it just looked gawdy and seemed like an accident waiting to happen so i removed it.is it possible that i have defective key switch?or maybe the wire going to the starter solenoid is not big enough to carry the voltage?or is there a starter relay in there somewhere that not right? im grasping at straws here,lol and need some direction. thanks
