Originally posted by Murray40
View Post
on going starter issue
The quick answer.....with difficulty. As u probably know Argo repair generally requires a little inspector Gadget/Macgiver know-how. However, I made the shield from a piece of v thin reflective sheet metal. Cut it to shape and sled it in between the block and starter. Pulled the two sides out, lapped and fastened. Not pretty but works. Caution:make sure the terminals on the starting unit are completely covered to prevent arcing with the sheet mental.
Originally posted by Skirdu View PostAssuming the new starter and battery are good all is left is ign sw ,wiring and solenoid. If youre getting a click probably switch is fine . I would make sure all wiring and connections are clean. Clean ring terminals battery connections. make sure no white powder on wires. Make sure ground connection on block is clean.your starter grounds thru its body so as long as the block mount is clean. Adding a ground to the starter would help anyways.
Can swap relay as well
Does your machine have a neutral safety switch?
If so bypass it and see if any change.
Originally posted by plott hound View Postever since i bought my 2012 hdi ive had and issue where 50% of the time when i try to start it i get only a click and no crank.release the key and try again and away it goes as it should.initially i thought the battery may have been weak so i chucked a good agm battery in but the same thing happened.took the starter out and replaced it with my brand new spare but got the same result.changed the spade connector that goes to the starter solenoid but there ws no change.i wired in a separate relay that took power right from the main power from battery then to the the starter solenoid.but it just looked gawdy and seemed like an accident waiting to happen so i removed it.is it possible that i have defective key switch?or maybe the wire going to the starter solenoid is not big enough to carry the voltage?or is there a starter relay in there somewhere that not right? im grasping at straws here,lol and need some direction. thanksWhat it lacks in ground clearance it makes up for with traction.
Battery voltage? I have a ZTR with a Kohler 27hp that did the same thing. If voltage went below 12.3 volts, I got the annoying click. The battery was switched out to a lithium Amazon special motorcycle battery and I use a 5 amp Lithium rated trickle charger. Problem solved for me. I would check the ground as well as the other connections as well as these bouncy machines tend to loosen their wiring.
Originally posted by Noel Woods View PostBattery voltage? I have a ZTR with a Kohler 27hp that did the same thing. If voltage went below 12.3 volts, I got the annoying click. The battery was switched out to a lithium Amazon special motorcycle battery and I use a 5 amp Lithium rated trickle charger. Problem solved for me. I would check the ground as well as the other connections as well as these bouncy machines tend to loosen their wiring.What it lacks in ground clearance it makes up for with traction.
