I have a 2003 8X8 conquest and have been trying to decide what type of tires to put on a second set of rims. I have supertracks so i need the runamuks on one set of rims. I looked at the ITP mudlites but they seem to have a very hard side wall and was told that the ride would be very rough. The rawhide IIIs look ok but I have read that some people seem to get a lot of flats with them. I see Rock Doctor on Utube has the Frontier tires on his conquest (also on his buddies conquest) and they really seem to perfom well and give a nice ride . When I look at the space between the runamuks especially on the front two tires (they seem to be a little tighter than the two rear) I wonder if they will fit without touching every now and then. Also does the larger 24" Frontier tire put excessive strain on bearings, chains and gear box or can the Conquest handle them with no problems? Also do you need to change the clutch tension? Any advice, info or recommendations on this subject is appreciated ( i still need the OK from the War Department for this budget expenditure, but it looks good for the spring of 2009) :hmmmm
). Even like this I can get the tires to touch each other when I hit a bump or hole too hard.
