I am really confused. I just had to replace the double sprocket on the second axle of my 2005 Avenger. This sprocket floats on its axle and that seems logical. However the single sprocket on the same axle has a set screw but it was not tightened when I went to remove it and it was floating on the axle too. In fact when I checked all the other sprockets on all the other axles they were all loose and they all float. The service manual is vague and says the “front” ones float. Does that mean the ones on the front axle only or the front sprockets on each pair of driving and driven sprockets throughout the whole machine? Too further confuse the manual says that after a certain date the set screws were discontinued.
Does anyone know which sprockets should float and which should be locked in place on an 2005 Avenger?
Thanks
Thanks
