John we talked about riding back on it and we’re not going to do that right away. We’re going to see if just driving over it gets it bound up in the axles, then if it doesn’t we are going to go the other way. I have a tractor with a cutter wheel on the back, but after it sinks 16” it’s over your stuck. My last STUCK with it was 150 yards away and we were snapping 5/8 cable. Finally went to 3/4 with snatch blocks to get it out. Needless to say I I bought 2 Argos. My max would put down more phrag in less time than that machine and rarely got stuck. When it did it was my own dumb fault. If it’s still a little green it will bounce back up about 2 ft. But once the freeze comes we drag 1” concrete form plywood over it and that works good. I tried pulling a 10’ telephone pole sideways threw it with the tractor 1 yr around august, as it came threw the phrag it bounced right back up and you never knew where I drug threw other than the tracks from the tractor. I’ll try to post some pictures of the different equipment we try to make work. Tomorrow at 2 o’clock I’m purchasing 2 swisher pull behind mowers. 1 is going on the front of a polar craft boat for cutting Lilly pads and the other we’re going to try to put either in front of or behind the Argos. If it works well enough they might both go on the Argos. We will build sleds under them so we can adjust the height then they can slide across the phrag. Wish I would have hit the powerball then I’d by the marshmaster
Tracks and phragmitis
sounds like a awesome plan ..we look forward to what you find . you sure would think something like a 4'' or 6 '' diameter piece of pvc pipe mounted so it covers the axles from tub to wheel hub would stop the entanglement . wonder why the argo is more prone than the max was . i'll stay tuned . jboy
Was a union pipefitter certified welder for roughly 20 years before going into the nuke world 9 years ago as a maintenance mechanic/welder. Having worked with cranes and rigging most of my life I've seen a lot of equipment pushed to its breaking point and I don't believe I've ever seen a cable break. I've seen them stretched, bent, kinked and frayed but not snapped. I've seen plenty of lifting straps break, partially tear, stretched beyond their working load limit etc etc. The point is I can attest to just how hard it would be to snap 5/8" cable!! That's a...wtf am I gonna do now...kind of stuck!! Things got real serious when you broke out the 3/4" cable and snatch blocks!! I love to come up with ways to solve problems that don't have a conventional or readily available solution so I'd definitely be interested in seeing the equipment you've made to battle the kryptonite...I mean phragmites lol....CupOriginally posted by Delduck View PostJohn we talked about riding back on it and we’re not going to do that right away. We’re going to see if just driving over it gets it bound up in the axles, then if it doesn’t we are going to go the other way. I have a tractor with a cutter wheel on the back, but after it sinks 16” it’s over your stuck. My last STUCK with it was 150 yards away and we were snapping 5/8 cable. Finally went to 3/4 with snatch blocks to get it out. Needless to say I I bought 2 Argos. My max would put down more phrag in less time than that machine and rarely got stuck. When it did it was my own dumb fault. If it’s still a little green it will bounce back up about 2 ft. But once the freeze comes we drag 1” concrete form plywood over it and that works good. I tried pulling a 10’ telephone pole sideways threw it with the tractor 1 yr around august, as it came threw the phrag it bounced right back up and you never knew where I drug threw other than the tracks from the tractor. I’ll try to post some pictures of the different equipment we try to make work. Tomorrow at 2 o’clock I’m purchasing 2 swisher pull behind mowers. 1 is going on the front of a polar craft boat for cutting Lilly pads and the other we’re going to try to put either in front of or behind the Argos. If it works well enough they might both go on the Argos. We will build sleds under them so we can adjust the height then they can slide across the phrag. Wish I would have hit the powerball then I’d by the marshmaster
Cup I think because of the length of pull and going around trees a scrub brush that is why we broke the cable. Then we got a little smarter and started using the snatch blocks. We learned a few things today…. 1 plastic tracks slip way more than rubber, 18 hp and 23 hp is plenty. Most important part is connecting, I’m sure there is another term for it. We were looking for every deer run and muskrat run so we could start there. Then we would only be able to 1/2 the machines on the high stuff. Definitely driving over it and not driving back against it helped TREMENDOUSLY with the phrag in between the tub and tracks. As far as the max, we’ll for any of the max lovers right now I don’t think there is much of a difference, but I’ve driven the max for years and I only have a few hours in the Argo. ( still love the max) I’m thinking I’m having a starter issue or a solenoid issue I’m going to replace the batt but the 03 machine didn’t want to start, we jumped it and it stated right up. The only thing I’ve done is put a new winch on so I disconnected it. Lastly I tested positive for COVID so now this is the 3rd time. Going to lay up for a day or two then head back at it. I’ll try to get some pics up later. We got maybe 1 1/2 ac today and that was 4 hrs, but we got the staging area set up with the ropes to the mainland and the boat. So now it’s just go and drive.
delduck ..get yourself some rest and feel better . i was thinking yesterday that it would really be interesting if you were in the phrag with your machine and another argo there with the mudd ox hybrid tracks and another machine with those steel plate '' escargo tracks just to see the comparison of how they perform and the phrag build up , etc. on different tracks , etc. j.b.
Sorry to here about the vid, good thing I didn't pop in and look around because the wife has me grounded due to not having a shot.Originally posted by Delduck View PostGuys I really appreciate all the feedback, I never thought I would get so much, and greatly appreciate it from all of you. Cup PSE&G just use there machines to go out to the power lines that cross the swamp so they do get phrag in the machines, but only a little bit since they are driving from a to b. Our world is drive over everything. Glyphosate is what I use, and it’s all about when. You can spray threw out the summer and it will stun it, but after it goes to seed you can whoop that a$$. And if you can be within 1 week of going to seed you can see it kill the plant within 2-3 days. After a couple weeks of going to seed the spray takes longer. This year we were able to spray all the way out till nov because of the warm weather but it didn’t show any affect until the second week of December. I’m going to run down 1/2 ac tomorrow and see how packed it gets, but I do think a pipe or even a angle bar across the front will help. Just funny how my max4 didn’t get wound up as bad. Just want to thank everyone for the replies and please keep them coming. About the first week in February we are going to video with the drone and use the go pro’s, hopefully I can download them to the site, if not send me a pm and I’ll send them threw email. Duck season ends on the 20th and we’re hoping to have cold weather by then.
Jb I think from what his problem is with the phrag the best track may be the beaver dam hybrid only due to it probably dropping and possibly chopping the phrag as the metal blade crimps it where there is ground contact.sigpic
Jim come on down anytime. I don’t have the shot either, so far so good, not a big deal, just a cough, not even a fever.we did learn that we prefer the individual sticks rather than the steering wheel. At least with the individuals you can keep one side moving while you chop the brake on the other side, not at all on the steering wheel machine.Last edited by Delduck; 01-01-2022, 05:55 AM.
Did I read that correctly, you've had COVID 3 times?!!Originally posted by Delduck View PostCup I think because of the length of pull and going around trees a scrub brush that is why we broke the cable. Then we got a little smarter and started using the snatch blocks. We learned a few things today…. 1 plastic tracks slip way more than rubber, 18 hp and 23 hp is plenty. Most important part is connecting, I’m sure there is another term for it. We were looking for every deer run and muskrat run so we could start there. Then we would only be able to 1/2 the machines on the high stuff. Definitely driving over it and not driving back against it helped TREMENDOUSLY with the phrag in between the tub and tracks. As far as the max, we’ll for any of the max lovers right now I don’t think there is much of a difference, but I’ve driven the max for years and I only have a few hours in the Argo. ( still love the max) I’m thinking I’m having a starter issue or a solenoid issue I’m going to replace the batt but the 03 machine didn’t want to start, we jumped it and it stated right up. The only thing I’ve done is put a new winch on so I disconnected it. Lastly I tested positive for COVID so now this is the 3rd time. Going to lay up for a day or two then head back at it. I’ll try to get some pics up later. We got maybe 1 1/2 ac today and that was 4 hrs, but we got the staging area set up with the ropes to the mainland and the boat. So now it’s just go and drive.
As far as the cable use is concerned, the length of the pull and any obstructions it may contact definitely has an impact on it's durability. I wouldn't think scrub brush and trees would be that detrimental to the cable but then again I have no experience using it that way. Not patting myself on the back but I had a feeling that the position of the phrag had a lot to do with contributing to the problem. Whether it was just the right length and flexibility as you drove through it initially or driving back through it. Regardless of what mechanical means you end up using or not using to remedy the problem at least you know now that it's not necessarily just the design of the ARGO or the design of the tracks that's contributing to the problem. More importantly than all that is your health so I hope your symptoms remain mild and under control. The county I live in is blowing up with COVID cases so I'm trying my best to avoid it. I'm kind of a homebody anyway so that part isn't hard for me like it is for others. I've been on vacation for almost 3 weeks too so that helps tremendously but come Mon morning that's all going to end when I return to work. Get some well deserved R&R and take care...Cup
Yes sir 3x first time I felt like death it was awful 2 nd time no fever just runny nose this time no fever just a cough but I feel fine, wife has me on lockdown tho. I get a antibody check once every 6 months, so far so good I’m up at 23% antibodies where as the shot puts you from 3%-7%. This is all here say I’m not a doctor nor claim to be but I haven’t had the shot, so I pay attention to my antibodies. Can anyone tell me if I have to pull the motor in a 2003 response 18 hp to put in a new starter and solenoid?
No need to pull engine to do solenoid, if it is not up on the hood frame it will be hose clamped to starter.Originally posted by Delduck View PostCan anyone tell me if I have to pull the motor in a 2003 response 18 hp to put in a new starter and solenoid?
You also do not need to pull the engine to change the starter but it is a chore due to lack of sight. You can use a mirror for better view, there are 2 small screws holding a guard around the drive that needs to be removed first, then just to tricky bolts holding starter. You must be careful not to pinch the stator wires as that will short the charging system. I'll try to get a pic later.sigpic
Wow 3 bouts of COVID...that's crazy!! Coworkers of mine have had it and they said the same thing that it was brutal. Some of them still have lingering issues like no taste, smell, cough, labored breathing and it's been months since they had it. How I haven't gotten it is beyond me because I was around several of those coworkers right before they were diagnosed and I didn't get it. Well...didn't develop any symptoms that is. Could've been asymptomatic and wouldn't have known without a test...CupOriginally posted by Delduck View PostYes sir 3x first time I felt like death it was awful 2 nd time no fever just runny nose this time no fever just a cough but I feel fine, wife has me on lockdown tho. I get a antibody check once every 6 months, so far so good I’m up at 23% antibodies where as the shot puts you from 3%-7%. This is all here say I’m not a doctor nor claim to be but I haven’t had the shot, so I pay attention to my antibodies. Can anyone tell me if I have to pull the motor in a 2003 response 18 hp to put in a new starter and solenoid?
Had to bring the machine back to the barn, hopefully just a batt problem. Tires were spinning in the tracks today. I didn’t do any real riding over phrag, just started the machine did a pass over stuff that was down and swam across the ditch. Getting out on the other side she was slipping. I have not checked anything yet, but figured I’d get some ideas. Not use to these plastic tracks, my rubber ones I didn’t have these problems I just broke things until one member told me to remove the front chains.
