Hey guys, I have some chain slap in my 2015 Argo frontier 8x8. I’m a little confused by the tensioner system on it. I’m trying to figure out if the tensioners are maxed out and the chains need to be replaced, or if the tensioner is not working properly.
Chain tensioner reached max?
If your tensioners are low your tensioners may not be moving freely if they are high your chains are probably worn. You can jack up machine and turn tires next to each other and rotate them in opposite directions to obtain slack and the manually pull up the adjuster but watch it as they will bite.Originally posted by ArgoAndrew View PostHey guys, I have some chain slap in my 2015 Argo frontier 8x8. I?€™m a little confused by the tensioner system on it. I?€™m trying to figure out if the tensioners are maxed out and the chains need to be replaced, or if the tensioner is not working properly.sigpic
