When I purchased my Argo last summer, I was not aware how hard installing the tracks could be until I used the homemade track installation from an old car jack. It only takes 3 minutes (if that) to install alone!
I had one tire with a tube that was installed on the end of the tracks (bad idea). I did not know that when I purchased the used argo (1987). The second ride using the tracks in the deep snow, I ripped the air valve. The solution was to install a new tube and install in the center. There is less chances that the tire and tracks will cause the rim to spin inside the tire.
I thought of sharing the pictures of the tool, so that you can make your own. I also used it to break the bead from the tire to replace the tube!
Now I can enjoy the riding on the snow and go deep in the forest.
