My 86 Response has a lot of chain slap turning either direction. I can feel it hitting the floorboard. Can a link be taken out? How tight should they be?
Chain Slap
while you are checking thins, you might want to check the wheel bearings, if jack up the argo you should feel no to very little movement, i thought that the chains were my problem, but turns out that the wheel bearings are shot too. i replaced my chains and will be doing the bearings her shortly. chains cost me about 400.00$ canadian
Darin
mud and ice
How many hours are on the machine?Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
probably time for some new chains. my 85 argo is in bad need of chain and i get the same slap on the floor that your describing. pull the floorboard and make sure the springs are still on the tensioners, but i'd bet that your chains are loose.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
Is this on your '84 model?, I just checked your previous posts. If so, I'm not familiar with the chain on that early of a model, in size or length. I've been buying the american made stuff at Shoup Manufacturing CompanyTo Invent, you need a good imagination and a pile of junk. (Thomas Edison)
