Can't say about the frontier but argo in general, you have to keep an eye on all that stuff. The primary chains off the trans, need to be kept adjusted. And lubed.. with a non slinging lube that won't get on the brake rotors. Someone else might have advice on the chain adjusters.
My new Argo Frontier
How many hours are on your Frontier? It takes many hours of running to even allow the chain adjusters to begin taking up slack. Sometimes the adjusters might stick in place (rarely) but other than that, they will take care of themselves. I've heard of a few vehicles getting very loose drive chains with low hours on the meter. However on most Argos, these chains require very little attention. I'm not sure how these hit and miss chain slack issues are popping up.Everybody dies, but not everybody lives.
There are only 8 hours on it. The manual says to check it after the first 2 hours for slack. It says it'll do a "banging" noise... which it did/sometimes does. I'm hoping I'm just being paranoid due to inexperience with chain-driven vehicles... just cautious... I hope.
---JIM---
I reject your reality and substitute my own...
(Mythbusters Fan
Chain Tensioner Mod..
Hi,
I just did a really easy and effective mod for the center wheels chain tensioner. I added a "helper spring" to the original spring that lifts the plastic block to give chain tension. It's the small coil-type "puller" spring that's attached to the frame member and the original spring...
So far, it works great... but is untested as of yet. I'll let y'all know if it holds
How do I add a video clip? I have a question and want to show my unresolved chain tension problems...
Thanks!
---JIM---
---JIM---
(Mythbusters Fan
I have been thinking about the same mod. That's just polly>>>> whatever it its right?
Basically the same stuff as a cutting board out of the kitchen! I have some of that at work for the slides on the wrecker. I'm buying a sheet of 3/8" for the bottom of my skid plate on my Jeep. No more hanging up on rocks!
The hydro tensioner idea would be great too! I see someone has replaced lots of Ford timing chains too!
Jeff
02 Argo Bigfoot
So, is chain slack ok at the center axles? I get a lot of chain "slap", hitting the bottom of the floorpan. The ratchet/tensioners are adjusted as much as possible.
Ok, honestly, do I just need to relax and not worry about this issue? Is it normal?
Thanks!---JIM---
(Mythbusters Fan
Hi,
I just wanted to share our fun from today.
My Wife, Shin, and I went to the Eldorado Dry Lakebed, which reverted to it’s prehistoric state after yesterday’s all-day rain!
Talk about FUN!
We went into some smaller puddles first to test it out. We got so drenched that we decided to just go for it and go into the middle of the “lake”.
After about 20 seconds, Shin “tapped out”, so I brought her back to the shore and she grabbed the camera.
The Argo didn’t even TRY to get stuck! It just kept on going…
Right before we left, I noticed a guy in a 3 wheeler trying to go through…
About 100 feet in, his machine quit on him… so I drove in to winch him out (backwards).
Still, didn’t get stuck.
We didn’t even think we had taken on any water until we pulled the Bilge Pump knob.
I took out the floor pan to find about 4-5 inches of muddy water!
It all came in through the cooling intake and exhaust grills… well, and probably the interior too, being that we were COMPLETELY drenched from head to toe.
We had to come home because the wind was too cold and strong to continue while we were soaking…
Click on this link to see a short video of the fun!
---JIM---
(Mythbusters Fan
