I bought a 98 argo with a 16hp briggs,The previous owner replaced the ignition switch with a riding mower switch.Every thing works good but it want turn the engine off.I tried grounding the coil kill wires to the frame and the battery and that did not kill the motor,Even tried unplugging all the ignition switch wire and ground it but that didn't work.Has anyone had this problem before,The only way i can stop the motor is to choke it out or pull the plug wires.
I put a 24 honda in my maxll and hooked up a ground switch that works good.
