I knew the time was coming to get into the Belly of the BigFoot,,,the other day my son was running it around the yard,,,could hear something clunking as it drove past,,,so I jacked it up today,,started on the right side center wheel/axle, thanks to "Rock Doctor" I just watched his video this am,,,to get prepared for this job,,,,found/pulled the 2 chains master link,,had the wheel off,,,spun the axel,,does not seem bad,,,but did clunk as it spun,,,removed the thrust bolt, bearing and gear set screws,,the 4 retainer bolt nuts,,,had to whack it good (bolt threaded into the axle end) with a 3 pound hammer,,then it all came loose,,, bearing seemed alittle growly when spun,,,,pulled the rest down, to get a bearing # 1030 1-1/4 GFS is what I find on the bearing,,,no numbers on the 2 different seals.
So I make my list,,,thinking they (ARGO) prob get $10 apice or so,,,they said $ 50 and change for each one,,,,,I almost dropped the phone!!! The guy says if the axel has groves from the bearing wearing on it,,,the new bearing will only last one yr !,,,OK so I ask how much for an axle,,,,he say,,,ummmm $60 bucks,,,,so you want $60 for an axel,,,and $50 for 1-one bearing,,,,I will look around here,,,thank you,,,but I do need the cork gasket,,ok 10 of them at $1.23 each,,and now the seal,,,NOPE,,, he says we dont stock them,,,they allways get wasted when trying to install them,,,so we sell the bearing end cap with seals and grease fitting already installed,,,,,OK, how much,,,,$33 bucks !
Man last time I ordered parts from here they were reasonable,,,,,But DAMN man !
Anybody got any seal #'s???,,,,I have a good bearing and seal,,, place going there in the am to find out how much it will cost me.
sorry for the long novel,,Just had to share,,,,,Later,,,,,,Mark
and he has to fix it.
, but it sounds like you have found a better place to buy. As for the Cork Gaskets, they are super easy to make, if you can get your hands on a "Bulk Roll" of Cork
, but he got stuck 3 times on Wednesday
, and I pushed him out each time and drove right through behind him
lol
LOL.
