Here,s some carb pics of my 18 magnum.Somebody rigged this spring up and it works well. Good luck.
1988 Argo 8x8
Hi george.I took a pic. but don't have the time for resizing right now.The spring on the govenor end is hooked in the farthest hole (toward back of argo). The govenor rod is in the hole next to it. My throttle cable is in the farthest hole (closest to the front of argo). As far as yor tires,Take them to someone that does it for a living, That way if they leak you can take them back and not be wasting your valuable time.Be sure to tell them to only use water as lube.Hope this helps.
what kind of tires, Mike
try this.
well if you can let me know what holes the linkage is in on both sides ill give it a try
thanks
