1988 Argo 8x8
  • #16
    Here,s some carb pics of my 18 magnum.Somebody rigged this spring up and it works well. Good luck.
    • #17
      sorry hit wrong buttontry this.
      • #18
        almost the pic i need but i want to see or confirm what settings to have the springs in on both the governor arm and the linkage arm thanks guys
        • #19
          Are you saying you have an actual spring on the govenor arm?
          • #20
            yes there were 2 springs from the throttle arm to the governor arm unlike yours ill have to snap a pic and let u guys tell me what need to be replaced
            • #21
              K i have some pictures in my gallery of the springs and linkage any help would be greatly appreciated thanks guys
              • #22
                sorry george i was away all day ill get you pics tomorrow
                "Argo 8x8's only" type of guy
                "old school Argo expert"
                • #23
                  Hey George, Mine works great the way it's set up if you want to give it a try. Only the one spring. I,m curious how eightwheeler has his set up.Now I have to look at the manual.
                  Mike
                  • #24
                    yeah seems like yours is solid linked by the rod instead of mine with the spring makes sense really just never knew how it is supposed to be.. well if you can let me know what holes the linkage is in on both sides ill give it a try thanks
                    • #25
                      mounting dismounting tires?
                      Whats gonna be my best bet getting my new rubber on the rim?
                      • #26
                        Hi george.I took a pic. but don't have the time for resizing right now.The spring on the govenor end is hooked in the farthest hole (toward back of argo). The govenor rod is in the hole next to it. My throttle cable is in the farthest hole (closest to the front of argo). As far as yor tires,Take them to someone that does it for a living, That way if they leak you can take them back and not be wasting your valuable time.Be sure to tell them to only use water as lube.Hope this helps.
                        what kind of tires, Mike
                        • #27
                          Thanks for the tip Ahh there just some new 22" Runamucks
