Hey, New guy to argos. I took my argo on a trip to michigan last weekend and every thing worked great until we went to load up. When you're sitting at an idle in gear it wants to roll and when you try to switch gears it grinds. Its wierd because it was fine all weekend. I'm thinking primary clutch opening up all the way at idle and is pulling on the belt. Has anybody experienced this?
Rolling at an idle.
Is it idling faster than it was before. Idling to fast will cause it to start pulling and make it hard to change gears(grind). First check the cable and make sure it is not hanging, it may need lubrication. Hope this helps!Originally posted by n9rracing View PostHey, New guy to argos. I took my argo on a trip to michigan last weekend and every thing worked great until we went to load up. When you're sitting at an idle in gear it wants to roll and when you try to switch gears it grinds. Its wierd because it was fine all weekend. I'm thinking primary clutch opening up all the way at idle and is pulling on the belt. Has anybody experienced this?Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
