I pulled the trigger on a 2004 Argo Avenger 8X8. It has 90 hours on it. I have agreed to purchase the Argo from a long distance away so I will inpect the vehicle when I pick it up. What should I look for? I also want to put tracks on it. The rubber tracks are extremely expensive so what do I have to do to put plastic super tracks on it?
bought my first Argo
Bob...Pull the floor boards and inspect all the chains and tensioners. If the tensioners are at max travel then the chain is in need of being replaced. I also look for cleanliness - if the inside is clean it was probabaly taken care of. Some people leave water in them, drain the engine oil into the bottom, never clean ect…this makes a mess and chain/bearing life is greatly reduced.
If you can raise the machine give each tire a shake checking for bearing play. When driving it make sure it runs well, turns both directions with the same effort.
