I found out the other morning that the conquest likes to be warmed up before going to work. It was in the teens. I tried to come up with a cheap throttle lock to set a high idle for the warmup. I know Roger uses rubber bands somehow but I couldn't get them to work. I tried two of the common wide variety. Any ideas of any sorts? I have an alternator and think it could be handy for this purpose too.
By the way, I set the idle by ear, sorta where the engine sounds like it is putt'n happy, but I probably should hook up the tach and check it. Where should it be set?
I guess while I'm in the questioning mood...
When the engine starts cold it is pretty clatter(y). I imagine contraction has added some clearance in places and cold oil is slower to move about. I'm hoping this is a normal thing. Or at minimum an "adjust the lifters" or "change to a lower viscosity oil" kind of thing.
I wonder if the additive (lucas I think I read) or the needle bearing conversion alleviate the problem?
