Well it's done.....Finally.
The 24" Frontiers are a real hit. They fit, they climb, they swimm, they are SELF CLEANING
, They look COOL
So like I said, a buddy came and took my new tires, put them on his Argo and tried them out......He won't give them back, he said he has already ordered me a replacement set + rims.
He has tried quite a few different tires on his Argos over the last 20 yrs, and he said NONE of them would climb like these!!!
He went swimming and said that "They are amaizing, they are fast and at full clutch engagement, will lift the front of the Argo about 4" up out of the water" (not thrust, lift) Anyway, MUCH faster than stock.
By GPS it looks like he gained about 2-3 mph, and he said that there was NO noticible difference in power.
He took them into some sticky mud, and said that they are very good at cleaning each other. At some points his tires were about 16" wide (exageration, I'm sure
), but the mud could not build up on the tire faces and never "Plugged up" between the tires and fenders.
He ran 2.5psi air pressure all day, through swamps, rocks, creeks, over logs. Aperently they are working very well for crossing logs, being as close togeather as they are.
, They look COOL
), but the mud could not build up on the tire faces and never "Plugged up" between the tires and fenders.He ran 2.5psi air pressure all day, through swamps, rocks, creeks, over logs. Aperently they are working very well for crossing logs, being as close togeather as they are.
