im removing my front axle on my argo and cant seem to get the sproket to buge its stuck on the 2 keyways have put heat and penetrating oil on and no luck the bearings and collers are loose wondering if any body has a trick too getting this thing off
axle problem
wrap a good heavy decking chain around hub.give yourself a foot or so of slack then whip the chain.this works good when removing auto motive axles.i had troubles removing the axles in my argo but i had the shell split and the engine removed.had to beat the bejesus out of axle with a sledge hammer and big brass drift.
Also a slide hammer will be quiet helpful. If you don't have one you can rent one from parts house.Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
no been having lots of bs with this axle put heat lots of heat and no movement in the sproket and its 2 keyways have not moved .I hade a small mishape in the shope last weekend and ive been out of buisness for the week had a 1inch sliver fly off my hamer and stick in my face all the way and my modeling corere is over but i will just cut the sproket off with a zipp cut and buy a new one
Thats sucks about your modeling career! Hope you are ok. Sometimes when you figure all the time wasted trying to remove something like that, it is best to just hack it off and buy a new one. Glad you got it. Hopefully you will be on the trails again soon!
ouch dude!supposed to leave metal chunks in face to us tinbangers.Originally posted by moose man View Postno been having lots of bs with this axle put heat lots of heat and no movement in the sproket and its 2 keyways have not moved .I hade a small mishape in the shope last weekend and ive been out of buisness for the week had a 1inch sliver fly off my hamer and stick in my face all the way and my modeling corere is over but i will just cut the sproket off with a zipp cut and buy a new one
well dudes surgery went well had too cut the sproket in half with a zipp cut and hamer a weg in and still had to hamer the heck out of it but now im home free will order a new one tomorow and now can move on to the rest of the problems like the fraims i was talking about before im trying too post some pics of them
