what type of fluid does the trans take in an argo? Its an o4 bigfoot.
argo fluid change
This is from a manual avail online that I frequently reference for my 2001 conquest. It was printed in 2005 and covers the conquest as well as the bigfoot.
"Refilling the Transmission
Refill the transmission through the oil fill/dipstick hole with 30
oz (.85L) of 80 W 90 Gear Lube HYPOY-C. As you refill the
transmission, check the oil level with the dipstick. Check that
the oil level is even with the mark on the dipstick, after it has
been seated fully in the dipstick hole. DO NOT OVERFILL."
Hope this helps. the man is at http://www.argoatv.com/_uploads/recr..._Models)v1.pdfsigpic
If you have the battery out, there's a bearing under there to grease..
I couldn't find hypoy C so I used synthetic
I like to use a chain lube that doesn't sling off on the transmission chains.. keeps it off the brake rotors.. the other chains I use whatever..To Invent, you need a good imagination and a pile of junk. (Thomas Edison)
