Started my rebuild today! Only one problem so far.
I cant remove the outer bearing set screw on the rear axles. I needed front outer bearing replaced but decided to do them all after I found the floor pan rusted threw at the weld in front of the hitch. I purchased HHK chain (He said a few of you guys were trying it out)from buffalo bearing to go all the way around and new bearings and seals also. My first project was complete (built a brushgaurd) so I decided to fix the rusted floor. That way I can sleep at night!
