I do want to clarify, I only use the covered switches, or in the 6x6 an in-1 so the float cannot move too far up. I do know some separate and external switches, can travel far enough up that the float actually tries to come down the other way, and will stay on, and can also get debris under them and stay on.
Also a switch not rated for GPH of the pump it's used on CAN weld on/fail. Would be like using a headlight relay as your starter solenoid.
I use auto in the 6x6 cause by the time I see water I've taken on quite a bit more than a few inches. Yes, I use a marine swith (scavenged from old boat) and as I had said, I do only put it in auto when swimming.
I have a pump indicator light on the boat that says when the switch is on, auto or manually. And I guess it's not a bad idea for an anphib either, dead battery OR pump isn't a good thing
EDIT: Beeman- Rule makes floatless water sensing pumps. They also shut off before any oil on the surface is sucked in, even if you filled it up with oil it would not switch on. I have never used those pumps, but I do use Rule pumps. If I kill the Attwood I have now in the Wolf, it would be replaced with a Rule.
