So what do you guys recommend for an Argo Conquest Battery?
I was thinking about a post that "number1cas" made on another thread about Ultima Batteries (the ones that look like a 6 pack
). I just had enough of buggering around with the Stock Size crappy batteries. Even fully charged they just barely turn the engine over when it's -30deg outside. The best I could get around here was only about 450 CCA, and total capacity is really to low for what I want. I spend to much time winching (Not necessarily becouse I'm stuck, but I move buildings, lift bridges, and whole Bison, ect)
I went and got one that I think is similar to what number1cas recomended, it has about tripple the total capacity, and about 1000+ CCA. It would NOT fit in the stock hole, so I just bit the bullet and mounted it on my back rack. It's about -25deg outside right now, and I went and tried the new battery.......Holy Crap. I hit the key and the starter damn near spun the Argo around. Fired right up, no problem. Now, since I have 2 Argo's, I think I should upgrade the second one as well, but I'm not to enthusiastic about kicking out another $300 for another one of these (There's not another one anywhere around here anyway, and the second Argo doesn't have a rack to mount it on). So, is there a recomended battery that will fit in the stock hole (5" wide, 9" long, and 8" high)?. Is a Deep Cycle Battery recommended for heavy winching.
NOTE, the Conquest that just got the upgrade has no alternator. The other one does have an alternator, and I've had no trouble with it yet, BUT, it's not my "goto" machine if I need to do lots of heavy work.
