I am changing a couple axle bearings on a 07 avenger EFI, never have done this before so I have a few questions. It is out in the woods at my cabin, so some of the questions might seem strange because I can't just go out and have a look. It has low hours(100).
Should I be changing both inner and outer even if one seems okay?
What size allen wrench will I need? I called the dealer and got an "I think" , so I thought I would confirm it. I have most sizes but want to be sure.
How do I get the chain apart? Is it a simple master link...or special tool?
Should I change the rubber seals, while I am at it, they seem rather inexpensive, even if they don't seem damaged?
I am a little concerned about the axle, what should I be looking for as far as knowing if it is damaged to the point that it needs repair or replacing?
What type of loctite should I use on those small allen key bolts?
Any "special" tools that I might need? I have most tools that I think I need, but someone out there might have a suggestion to make the job easier.
Thanks in advance
Chuck
Thanks in advance
Chuck
