Hi, I changed the oil transmission in my argo avenger (2005). In the manuel they say to put castrol hypoy C 80W90. I did not have it in hand but I had another brand 80W90 but it doesn't say hypoy C on it. Does that make any difference or is it just because argo has a deal with castrol since they often suggest castrol.
oil transmission
I add about 15 squirts from a grease gun of synthetic grease to the transmission oil.
On my conquest the top shaft on the transmission doesn't get any lubrication if it idles in neutral. I think the grease and oil mix will stay on the shaft longer and I try not to idle it very long. So far no problem.
SlimSlimpickin
