Okay....so I went ahead and replaced my axle sprocket Spirol pins with Holo-Krome 1 3/4" shoulder x 5/16" diameter shoulder bolts (Part #08030).
The problem is every bolt head (and nut) interferes with the side of the sprocket. The factory holes are drilled right next to the sprocket face at nearly all locations, and with pins that wasn't such a big deal, but with bolts it sure is.
The only solution I see is to grind one side of the bolt head flat, and forego the nuts and drill a hole through each bolt and install a cotter pin to hold it in place. In essence, I'm creating a dowel pin.
Anyone have any better solution for this one?
Thanks guys,
Planter Bob
Thanks guys,
Planter Bob
