Hi all,
I have started to try and pull the axles out of the Argo, wow what a job! I have not even got one out yet as they are tight and rusted etc. I have even knocked the roll pins out and cannot get the sprocket assembly to turn on the shaft! It is so tight, unless I am missing something?going to try heat next weekend.
I want to put new bearings, flanges, axels if needed,chains in the Argo. I would like to order all the gear from a supplier and have it shipped to me. Is Richards relics a good place to do this?I have sent an email but no answer as of yet so not sure of this.
I also would like to put tracks on ( have emailed Richards relics regarding axle extensions) what other upgrades should I complete to ensure the tracks work ok?
Am I able to upgrade to the splined axles? Do I need them?
Also has anybody upgraded from mechanical brakes to hydraulic? I would like to do this, I have not seen a newer model but assume the steering arm works 2 hydraulic master cylinders. Can I buy this from somewhere? Or off an old parts Argo someone has?
All help is appreciated.
Cheers
Corey
Cheers
Corey
