Rear brake
  • Rear brake
    Guys,
    This is the rear brake on my 8x8 I mentioned in another post, does anyone else have this brake? And if so why is it only on the right side?
    Any thoughts?
    Cheers
    Corey
    sure looks to me to be an add on. The upright that the shaft for the rotor mounts to is not concentric. I would expect a factory piece to be a bit cleaner. The rotor and caliper are the same as used on a Tri-Cart, although they were probably used in other applications. I suspect someone needed a parking brake and fabricated it. Do you have the rear floor pan? how does it fit around the brake assembly? That might tell a lot. Also, how is it actuated?
      yes you are right its an add on someone put on trying to get more braking power out of the turning system or even a handbrake, its a rotor and mechanical brake from a transmission, i personally would cut it off
      "Argo 8x8's only" type of guy
      "old school Argo expert"
        Thanks guys,
        It is connected to the right hand side braking lever, so it operates with the right brake. I have the pan but have not really taken any notice of how it goes around the brake disc. The cover that sits over the disc is fiberglass which probably another tell tale it is an add on.
        If I don't need it I will remove. I want to upgrade to hydraulic brakes and was thinking I needed a third caliper, guess not now :-). Just need to work out best method to do it, would like to change to the turn handle instead of levers.
        Corey
          Interesting. Must have been installed for someone like my late mother-in-law. She planned her trips around town so that she only did right turns.
          I bet the experimenter did the right side, played with it, and decided it wasn't worth the effort and skipped the left.
          I was kind of hoping to see something like an ebrake that went right to an axle. I ride mine up and down some pretty steep sandhills in NE all the time. Rock Doctor had to (in another thread) point out that there are a couple of chains that can break between the rotors and anything that actually touch the ground...
          Maybe someone wanted a redundant setup for hills?
            I think I should remove it, agree? I also think it may be why I have issues turning right, I think if not adjusted correctly it is more of a hinderance than a help.
            Thoughts?
            Cheers
            Corey
              yes get rid of it, ill check to see if your trans will fit calipers so you can convert to hydraulic brakes
                I would really appreciate any help you could give with the hydraulic conversion.
                Thanks again.
                Corey
                  Hi eight wheeler
                  Mate did you have any luck with investigating if I can fit hydraulic brakes? I would appreciate your thoughts?
                  Cheers
                  Corey
                    I apologize i have not, we just got contract with Bombardier so crazy crazy busy but that is a good thing in these days of bad economy news lol, i might have time Sunday
                      No problem mate,
                      When you have time is cool.
                      Cheers
