Today I worked on the fresh air intake some. As I'm swapping the liquid cooled motor with an air cooled one, I wanted to build some ducting to allow the motor to get the coolest air possible. I debated using metal vs plastic. I think metal would be the easiest, using prefabbed duct work, but I decided to try my hand at some plastic welding and I went with HDPE. I purchased a full sheet of HDPE to use for this as well as, eventually, a firewall. I had previously measured and modeled the duct work. Today I cut out the pieces. I've got a couple of adjustments to make and then I will start welding.
I debated over which plastic welder to choose and ended up with a cheapish one from ebay. The main reason I purchased it was for the "high speed" tip. This allows you to feed the plastic rod down into the welder instead of having to work the material by hand. In the photo you can see the green welder, most of the pieces I cut for the fresh air intake as well as the plastic welding rod on the left hand side in the long bag.
How 'bout having them shove you out with a parachute over our house for a few hours? We'll have coffee.
There really isn't much left:
