hi mike! i have a source for 10:1 taper adapter for using a snow mobile clutch on a straight keyed shaft. Please consider this, as every comet clutch set up is 2:1 starting and 1:1 final drive, vs a snow moblie clutch 4:1 starting and a .76:1 over drive!!! it is like having low range on tap, all the time!!! If your going to spend the money on new clutches... get ones that give a HUGE mechanical advantage! let me know if i can help... having "almost low range" in that argo with the T-20 will be killer!! i can even help you "tune it" so it work for you.
Also, google search "snap idle automatic chain adjusters" That is the best bang for your buck! if you have to, i know Msfia used the on the T-20 to jack shaft in a hustler... he just had to put a piece of steel out to keep them from sliping off on the transmission side....
