Can anyone tell me the difference in speeds between the MU and GU Argo transmissions? I have an MU (medium) and am thinking of switching to a GU (low) for more power but would like to know how much speed I will sacrifice if I do this.
Tramsmission speeds question
Maybe, but I am also interested stress and strain. My conquest is used for work and often carries a heavy load (800+ lbs) plus pulling a heavy trailer (1200 lbs.).
Just figuring a GU would hold up better under my conditions. Am I thinking wrong?
I have one with the GU and one with the MU. The only real difference you will probably notice is that you will run in Low Range less often with the GU. Stress and Strain on the machine will not change, the only thing that may hold up better will be your Belt.
I would add that the machine will defiantly "feel" better while navigating tight trails, hills, and holes .... IMHO.
I prefer the GU over the MU for hauling heavy loads.
