This thread is to be the master thread of the argo build. I am going to reinforce the frame, tie it more efficiently into the body, and put HDI axel shafts in it. Also, a geo metro engine with Polaris RMK clutches will be inserted. I dont know what it will be when i get done, but this is the beginning.
Before we get started, i would like to point out that im doing this build in my gravel drive way, I got a 220 wire feed and stick welder for 300 dollars, and a Oxy-Acytlne rig for 200 bucks, and a new grinder from wal mart for 30 dollars. I dont have an air compressor, so all wrench spinning will be done by hand. I believe that if anyone drags home a GOOD tub and good frame and a transmission for ANY and i mean ANY AATV you should be able to apply the formula im attempting to put together. I just happen to have an Argo.
The beginning:
Note the polairs primary in the background
Put on some marvin grey for the geo and argo... no luck. Guess ill have to do it the hard way
Looks kind of cool with HUMVE doors.. but that is probbably a month away
My super visors, supervising and hiding tools
working on GEO wiring
upper body off
Saggy sides
saggy bottom tub too
Still Lots of work to be done. It has the LONG axels in the front, anyone have a neat fix for that to replace with short ones?? I know i am going to have to build some more frame but if you had any pics that would help.
Looks like the picture links as URLS arnt working for the new album. It can be seen here until i get it figured out. The tear DOWN of old green
The beginning:
upper body off
Saggy sides
. Are you installing the HDI Outer Axle Bearing Assemblies to go along with the axles?
But thanks for helping good buddy! cant wait to see the drawing. guess i had better go get that frame out of there so i can do some work on it! And they quit putting the tube in there for the HDi machines.... different bearing extensions too!
