hi guys, im starting a project with my argo.
Im planning to install a G10 engine from a pontiac firefly 94 efi and will put some pictures and videos while im building here and there.
Here is the beast
here is the engine pulled from a donor car with everything working, i had to mess up with the starter a bit but everything is all right yet.
and some wiring mess on the table hehe
more to come
24-11-2012
A box i made for protecting the ECM, will be waterproof, and shockproof
The original G10 fuel pump from the donor car, I just cut the flange plate in half and remove the fuel sender to fit on the argo tank
Hole for the fuel pump installation
result
Hood lift modification for the G10 engine, still not done yet hehe
Here is the adapter, made from 1 piece hardened shaft
and the clutch puller here
adapter bolted on the flywheel, only 3 bolts for now :P
the clutch fitted on the engine, need a shorter bolt, 7'' should do the trick
driven clutch on the transmission
I used the original trans/engine mount that im modifying for the purpose. Lowered 1.5 '' and braced for extra strength
general view of the thing, no support done yet, Im waiting for my universal alignment tool to get this done
more to come!
Here is the beast
more to come
24-11-2012
result
more to come!
