Project Bush Machine
  • trevorakm1
    replied
    I really like tat cap you got there, the sliding doo is kool!
  • prailleraide
    started a topic Project Bush Machine
    hi guys, im starting a project with my argo.
    Im planning to install a G10 engine from a pontiac firefly 94 efi and will put some pictures and videos while im building here and there.
    Here is the beast
    here is the engine pulled from a donor car with everything working, i had to mess up with the starter a bit but everything is all right yet.
    and some wiring mess on the table hehe
    more to come
    24-11-2012
    A box i made for protecting the ECM, will be waterproof, and shockproof
    The original G10 fuel pump from the donor car, I just cut the flange plate in half and remove the fuel sender to fit on the argo tank
    Hole for the fuel pump installation
    result
    Hood lift modification for the G10 engine, still not done yet hehe
    Here is the adapter, made from 1 piece hardened shaft
    and the clutch puller here
    adapter bolted on the flywheel, only 3 bolts for now :P
    the clutch fitted on the engine, need a shorter bolt, 7'' should do the trick
    driven clutch on the transmission
    I used the original trans/engine mount that im modifying for the purpose. Lowered 1.5 '' and braced for extra strength
    general view of the thing, no support done yet, Im waiting for my universal alignment tool to get this done
    more to come!
