TTT updated.
I have purchased secondary and primary polaris from ebay. I'll probably use an argo belt cause its a bit longer. Just adjust driven and add or remove spider shim on clutch to get the good belt to sheave clearance.
I found a machinist that will make my adapter on a 1 piece hardened shaft. I will probably get the adapter in December
For now I am working on other stuffs ; custom dash panel with access on back; hood lift to fit the engine;
For the engine i am waiting for the adapter to start building engine mount / plate, i will use the original trans/engine bracket, that i lowered a bit to get clearance (1.5'') and will solidify with braces.
i got one by mistake.
